datanaut
Projects Window List in JMP 15 for Mac -- Reorder?
I'm trying to use JMP projects more with the promise of re-using graphs and analyses on new sets of similar data.
I'm using the Window List in the UL as a kind of 'table of contents' that I can click into to see/show my findings for various analyses.  There is a flow to the findings which I'd like to order in that Window List.  Is this possible?
I can't click and drag an entry for a window up or down.  I can reorder the tabs but that doesn't seem to affect the window list order.  New windows appear at the bottom of the list.  If I had several graph builders I wanted to cluster together, how could I do it for example?
JMP® 15.2.1 on Mac on MacOS 11.5.1 Big Sur
0 REPLIES 0
