First of all, thank you very much for your replies and i am very sorry that i can only respond now....
To provide some background, this is the theoretical graph we are expecting and the slope and time lag are the corresponding results.
In our experiment we are acquiring data points over the course of days and are expecting a slow increase in slope and then the reaching of steady state (i.e. only minor fluctuations in slope). Subsequently the slope will flatten as additional factors come into play. As these are real-time data points, sampling over night is not possible which results in gaps in the data points and as this setup is new we do not know whether steady state is reached at day one or day 5. Once this is more clear we will add additional sampling points in the area of interest. To find out about this i need to identify the timeframe when steady state is reached and this is what my question is relating to. So for example with this data set:
i can already see that the first and the last set of data points are not relevant so i am excluding these data points.
Looking at these data points that are left i am looking for a tool to decide which data points should be included as they contribute to the accuracy of the slope at steady state and additional effects before and after the steady state are excluded. For this i had so far created linear fits while excluding more and more data points and then looking at the R2. You mentioned looking at the residuals, is there a cutoff you would recommend? I will add the residual plots below.
Thanks again for your responses!
