Identifying multiple Peaks in different batches
Hello everyone,
I have a data set similar to the one in the example below, but the length-time profiles are assigned to different batches indicated by an additional column with the batch nr.
Solved: find multiple peak values in a column - JMP User Community
Is there a way to adapt the peak detection column formula in the thread above to perform the peak identification for each batch?
Thanks in advance!
Re: Identifying multiple Peaks in different batches
Which JMP version are you using (JMP17/18? JMP Standard / JMP Pro?) as there might be jmp platforms to do this. Column formula could also be modified by adding additional check for the batch changes.
This is one possible formula option (:B is group column)
New column("Peak", Numeric, Nominal, Formula(
	prev_val = Col Moving Average(:Length, 1, 1, 0, :B) * 2 - :Length;
	next_val = Col Moving Average(:Length, 1, 0, 1, :B) * 2 - :Length;
	:Length - prev_val > 0 & :Length - next_val > 0
