I will show you the changes necessary to do what you want, however, I will do it by showing you that you could figure this out all by yourself, because JMP will show you how to do this.
Your request is to change the name of the Outline Box that is created that repeats the title, "Individual Measurement of Mean(Runtime)". So, the first step is to simply change that title in one of the outputs.
![runtime1.PNG runtime1.PNG](https://community.jmp.com/t5/image/serverpage/image-id/10459i9D454385C3B93D55/image-size/large?v=v2&px=999)
Then go to the red triangle and save the script for the changed chart
Control Chart(
Sample Label( :Date ),
Group Size( 1 ),
KSigma( 3 ),
Chart Col( :Name( "Mean(RunTime)" ), Individual Measurement( LCL( 0 ) ) ),
Where( :Sub_name == UnitNames[i] ),
Dispatch(
"Individual Measurement of Mean(RunTime)",
OutlineBox,
{Set Title( "This is the title I want to have" )}
Dispatch(
{"Individual Measurement of Mean(RunTime)"},
"2",
ScaleBox,
{Format( "hr:m:s", 13, 0 )}
Dispatch(
"Control Chart Limits frame",
FrameBox,
{Frame Size( 64, 208 )}
Note how JMP indicated how to change the chart to make the Outline Box title a different name
Dispatch(
OutlineBox,
Now all you have to do, is to reincorporate this change back into your script, and substitute the title for the UnitNames[i], which is your list entries for your requested Sub_name
New Window( "M11 Runtime times Summary - Control Chart",
V List Box(
For( i = 1, i <= count_UnitNames, i++,
Control Chart(
Group Size( 1 ),
KSigma( 3 ),
Chart Col( :Name( "Mean(Runtime)" ), Individual Measurement( LCL( 0 ) ) ),
Dispatch(
OutlineBox,
{Set Title( UnitNames[i] )}
Dispatch(
{"Individual Measurement of Mean(Runtime)"},
"2",
ScaleBox,
{Format( "hr:m:s", 11, 0 )}
