IMPORT EXCEL FILES VIA JSL - COLUMN FORMAT
Hi all i am using JSL of JMP 11.
I want to import and excel file.
Is there a way to force JMP/JSL to import ALL COLUMNS as TEXT (CHARACTER) ?
My columns have empty cells and text and number. The script I wrote in JSL automatically read them as number, therefore putting missing values in my text cells.
I want to import them as text.
here the piece of code.
dt = Open("mydata.xlsx",
Worksheets( {"Sheet1"} ),
Use for all sheets( 1 ),
Concatenate Worksheets( 1 ),
Create Concatenation Column( 1 ),
Worksheet Settings(
1,
Has Column Headers( 1 ),
Number of Rows in Headers( 3 ),
Headers Start on Row( 1 ),
Data Starts on Row( 4 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 0 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Treat as Hierarchy( 0 )
Thank you.
Angela.
pmroz
Re: IMPORT EXCEL FILES VIA JSL - COLUMN FORMAT
Not sure how to do it directly, but you could add a post-processing step:
dt = open("$sample_data\Big Class.jmp");
col_list = dt << get column names(Numeric, "String");
for (i = 1, i <= nitems(col_list), i++,
      column(dt, col_list[i]) << data type(character);
pmroz
