Hi - I am trying to create and populate a group of new columns based on results of an if/then statement.
STEP 1:
I need to create the new empty columns that will be populated.  (55 in all)
(Each new column is a numeric, continuous field.)
The name of each column will correspond to the name of each of the 55 compounds in the group followed by "_ppt".  E.g. the compound named "4:2 FTS" results in a new column named [4:2 FTS_ppt].
STEP 2:
Row by row, I would populate the new columns using an if/then statement that evaluates three existing columns associated with each of the 55 compounds in the group.   Specifically,
if  [RES_VALUE_4:2 FTS] >=  [RL_4:2 FTS]       THEN      [4:2 FTS_ppt] = [RES_VALUE_4:2 FTS]
if [RES_VALUE_4:2 FTS] <  [RL_4:2 FTS]     AND     DETECT_FLAG_4:2 FTS] = N      AND    [RL_4:2 FTS] <= 3    THEN  [4:2 FTS_ppt] = 0.0009.
if [RES_VALUE_4:2 FTS] <  [RL_4:2 FTS]     AND     DETECT_FLAG_4:2 FTS] = N      AND    [RL_4:2 FTS] > 3    THEN  [4:2 FTS_ppt] = NULL.
Here are the existing column names with a suffix that is the compound name.  I am using JMP Pro 17.0.
Any guidance would be most appreciated!
