Markku
I lost my ability to do drag and drop into graphs i graph builder.
I lost my ability to do drag and drop into graphs i graph builder. I get a red stop sign when i try. The only way is to first mark the axis and then clickon a varaible. Itried to use the deselecting the accelarate graphics help hiven for olsd versions od JMP - it did not Help
This happend yesterday in JMP pro and today when i installed the JMP 18.1 it behaved in the same way. Did not work. This is a major problem. When I mark  and start dragging the variable it shows  a red - "Do not drive in this direction sign"
Re: I lost my ability to do drag and drop into graphs i graph builder.
I have the same issue using Windows JMP Pro 17.0. Last night it worked and this morning I can't drag and drop (red stop sign) and it seems to be lagging.
The only update my PC did overnight was:
Security Intelligence Update for Microsoft Defender Antivirus - KB2267602 (Version 1.421.1944.0) - Current Channel (Broad)
and
Logitech - USB - 1.1.55.3120
I tried the instructions in the old post (https://community.jmp.com/t5/Discussions/I-have-lost-the-ability-to-drag-and-drop-columns-in-graph/t...), but they did not work. Did you find a solution to the problem?
Many thanks!
