galactus3000
I have some cells selected ... how do I set the values of those cells?
I have a script which has already selected a set of cells.
Now I want to set those cells to have a certain value, say 6.3201
why doesn't the following work?
set selected cells(6.3201);
I know how to select the cells and don't need help with that
I need help with how to take a group of selected cells and simple want to place a value in them
thanks
Re: I have some cells selected ... how do I set the values of those cells?
Assuming the selected cells are all in the same column, and let's say the column is named "X", you would set the values
X[ dt<<get selected rows ] = 6.3201;
I am also assuming that you have specified prior to the above:
dt = current data table();
