CanhKhong
Sort ascending script
I would like to know how to creat a scrip of sort ascending on one of the column in my JMP file and thanks.
Craige_Hales
Re: Sort ascending script
cwillden
Help > Scripting Index > Sort
-- Cameron Willden
@cwillden is providing a good place to learn how to do this.  Another approach, is to simply do the sort interactively, and then in the new data table that is produced as a result of the sort, right click on the green triangle in front of the "Source" entry in the Table Panel on the upper left edge of the data table display and select "Edit".  It will show you the script that JMP used to create the sorted data table.
Craige_Hales
