dwaterson
I have a column of comma separated numbers. Is it possible to separate each number into its own column?
Jeff_Perkinson
Re: I have a column of comma separated numbers. Is it possible to separate each number into its own column?
The Text to Columns, Version 2 add in will help you out here.
-Jeff
-Jeff
Jeff_Perkinson
-Jeff
-Jeff
dwaterson
Hi Jeff,
Thank you for the Text to Columns add-in. It loaded well and ran well. It did take some time to go through the >5 million rows of data and >40 comma separated values, around 5 mins. So much better than creating a programming each column myself as that would take much longer!
Dianne
