Thanks you very much.
Please help to clarify whether my analyse step is correct or not. I use one mean tutorial and Candy jmp file.
1. I plot distribution to find out whether it is normal distribution or not.
2. Select continuous fit ==> Normal
3. From fit normal red triangle ==> select goodness of fit
4. From note: Ho = The data is from normal distribution. Small p-value reject Ho. This mean data is not normal distribution.
![PastedGraphic-1.png PastedGraphic-1.png](https://community.jmp.com/t5/image/serverpage/image-id/13021i0A3AC32350B01D1B/image-size/large?v=v2&px=999)
From tutorial, they use test mean to verify. But this data is not normal distribution. We should use test median instead of test mean.
Question: Please confirm my understanding above correct or not. This is what I learnt many year ago.
If my understanding correct. Can I get test median from red triangle of histogram or not. If not, how can I get it.
![PastedGraphic-2.png PastedGraphic-2.png](https://community.jmp.com/t5/image/serverpage/image-id/13022iD4FA8D59452E4164/image-size/large?v=v2&px=999)
