CrownofTears
I cannot add USL and LSL to my variability chart automatically
Hi Guys,
I am trying to have my Variability charts generated automatically with LSL and USL. This is the code I am using.
This code runs but it does not generate the limits in the chart. Do you have any idea of what io am doing wrong?
DeltaVar= New Window("GRR Delta Report",
		For(l=1, l<=Nitems(ListDelta),l++,
			tres=Variability Chart(
				Y(ListDelta[l]),
				X(:Chan, :SN),
				Model (Crossed),
				Historical Sigma (0),
				Connect Cell Means (1),
				Show Group Means (1),
				Show Grand Mean (0),
				Show Grand Median (1),
				XBar Control Limits (1),
				S control Limits (1),
				Std Dev Chart (0),
				Mean Plots (0),
				Mean of Std Dev (1),
				Add Spec Limits({LSL(-0.1),USL(0.1)}),
				Show Spec Limits(1),
Re: I cannot add USL and LSL to my variability chart automatically
I don't think Variability Chart supports "Add Spec Limits". You could add the spec limits to your columns as Spec Limit column properties.
ListDelta = {"height", "weight"};
Column(dt, "height") << Set Property("Spec Limits", {LSL(50), USL(100), Show Limits(1)});
DeltaVar = New Window("GRR Delta Report",
	For(l = 1, l <= N Items(ListDelta), l++,
		tres = Variability Chart(
			Y(Eval(ListDelta[l])),
			X(:sex),
			Model(Crossed),
			Historical Sigma(0),
			Connect Cell Means(1),
			Show Group Means(1),
			Show Grand Mean(0),
			Show Grand Median(1),
			XBar Control Limits(1),
			S control Limits(1),
			Std Dev Chart(0),
			Mean Plots(0),
			Mean of Std Dev(1)
			X(:sex),
			Model(Crossed),
			Show Grand Mean(0),
			Std Dev Chart(0),
			Mean Plots(0),
			Mean of Std Dev(1)
statman
There may be other ways, as Jarmo indicates you can add spec limits to the properties of the column
Then when you create the Variability plot, check the box at the bottom:
