lwx228
Level VIII
I can't even do this simple replace!
Not found in the script index, please finish with JSL.Thank you very much!
5 ACCEPTED SOLUTIONS
ian_jmp
Level X
Re: I can't even do this simple replace!
You could use data table subscripting:
NamesDefaultToHere(1);
Wait(3);
maleRows = Loc(dt[0, "sex"], "M");
dt[maleRows, "sex"] = "boy";
lwx228
Level VIII
I've tried to write JSL in a way that only works with perfectly matched substitutions, but if you don't want to replace only a few characters, how do you write JSL?Thank you!
This is one way to do it
dt:class[dt << get rows where( dt:class == "A1" )] = "A9";
ian_jmp
Level X
That is not all the ways it  can be coded in JSL to accomplish what you want, but Ian's suggestion is what I would have also suggested as the solution.
14 REPLIES 14
ian_jmp
Level X
Wait(3);
lwx228
Level VIII
It seems to be quite different from the VBA approach.thank you!
lwx228
Level VIII
lwx228
Level VIII
If this is the new case, this JSL is not very efficient.Can the code be improved for the new instance?Thank you!
ian_jmp
Level X
If I understand correctly, consider using the 'Match()' JSL expression. I generated the code below by using 'Cols > Recode':
and inspecting the JSL for the resulting formula column. And, 'yes', JSL is very different from VBA. You should look at 'Help > Books > Scripting Guide' and/or consider some training.
Wait(3);
dt << New Column( "Age 2",
					Character,
					"Ordinal",
					Formula(
						Match( :age,
							12, "Twelve",
							13, "Thirteen",
							14, "Fourteen",
							15, "Fifteen",
							16, "Sixteen",
							17, "Seventeen",
							Format( :age, "Fixed Dec", 5, 0 )
lwx228
Level VIII
I'm so sorry!Maybe the example I gave is not appropriate and misleading.
I just want to replace some of the specified characters with others in the same column.That is the manual interface function, just want to use JSL implementation.
The VBA implementation in excel is simple:Selection.Replace What:="1", Replacement:="9", LookAt:=xlPart
I just want the effect of this simple trade effect.But I don't have the corresponding code in JSL.Thank you!
lwx228
Level VIII
This is the result of the substitution in the case of "Match entire cell value" the multiple checkbox is not selected.Thank you!
lwx228
Level VIII
It's just a matter of replacing some characters in a cell with JSL.
