kanpiner
I/O error when close a data table
Recently I just installed JMP 15. Whenever I attempted to close a non-empty data table, the log will pop up with the following error message:
"Save changes to the JMP Data Table Untitled 25?
I/O problem.
Untitled 25.jmp
Unable to open in ReadWrite mode.
The system cannot find the file specified."
The table has nothing special. I just created a new one and type in random words in the cols;
I have tried reinstall jmp, no help; tried to change directory folders I am sure to have access with, no help;
This problem is really annoying and not sure how to get rid of it.
Any suggestions will be appreciated!
stan_koprowski
Re: I/O error when close a data table
Hi @kanpiner ,
I would contact technical support (support@jmp.com).
They can best help you come to a resolution.
cheers,
Stan
pmroz
Have you tried updating to JMP 15.1?
Zahti
In JMP 15 there are some extra parameters for the Close(); function that were not required in JMP 14. I just found this out today as well and it is quite frustrating... broke all my scripts :)
JMP 14 syntax:
Close( "Table1" );
JMP 15 syntax:
Close( "Table1", NoSave );
Hopefully this helps!
pmroz
The nosave parameter has been part of the close() function since at least JMP 11, if not earlier.  I tried creating a table and then calling close(dt) in JMP 14 and 15, and the table closed no problem.  Interesting though - the table was automatically saved to my desktop.
As a rule I call close() with the nosave argument if I've got some temporary work tables.
How did this break your scripts?
rcookie
Had the same issue, adding the nosave argument fixed it (JMP15).
