  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
ashwint27
Create new columns that add data from existing columns to one fixed column
Let's say I have one column with numeric-continuous data.  This data is my "reference" data.  I have n other columns with numeric-continuous data.  Is there a way to create an additional n columns where each of these new columns is a sum of the first "reference" data column with each of the n other columns?
Re: Create new columns that add data from existing columns to one fixed column
Hi, you can do this as follows:
1) From the main menu, select Cols > New Columns... and add N columns by typing that number into the Number of Columns to add box. If you like, add them as a group and type something into the Column Prefix box.
2) Highlight all the new columns, right-click in the column header area and select "Standardize Attributes"
3) Under Column Properties, use the drop-down to select Formula:
4) Select "substitute column reference" and then click Edit Formula:
5) Enter the first formula and click OK:
6) Uncheck the reference column checkbox. The input should look like below. Then press OK.
7) The results show formulas as desired:
Cheers,
Brady
Cheers,
Brady
ashwint27
Thanks, this is exactly what I was trying to accomplish.
