mkennke
I/O Problem. Unable to get End of File marker. Unable to get End of File marker.
I have a problem with my script.
I am running a script that modifies a data table which will be saved after the change (not closed). Other colleagues use this file (only read, not write mode). But unfortunately, I got now different types of error messages within the Log window. And on top the file is not saved.
The messages are:
I/O Problem. "somthing with File Bufffer, but I forgot it :-("
Does anybody know what the failures are and how can I solve it?
Grüße,
mkennke
etran
Re: I/O Problem. Unable to get End of File marker. Unable to get End of File marker.
I have the same problem!
May this thread helps you: https://community.jmp.com/t5/Discussions/I-O-Problem/td-p/40248
/****NeverStopLearning****/
