User Input List for Regression Analysis
I have an input box where users can select columns to be run in a regression report. (Long story on why I want to do this.) This part works great. I then insert the list of columns into a list. When I try to put the list or even just a few of the column names into the regression report. It doesn’t work. What should I do to make this work?
The user input list readout looks like this: {"Column 1", "Column 2", "Column 3"}
platform = dt << Fit Model(
       Y( :Char(variable)),
             Effects(
                           What should go here?????
       Personality( "Generalized Regression" ),
       Generalized Distribution( "Normal" ),
       Run(
             Fit( Estimation Method( Two Stage Forward Selection ), Validation Method( AICc ), Enforce Heredity )
Re: User Input List for Regression Analysis
Place your list within an Eval() function and you should get what you want
myList = {<your list of columns>};
	Y( :Char( variable ) ),
	Effects( Eval( myList ) ),
	Run(
		Fit(
			Enforce Heredity
This works well for my initial list. What if I want to have interactions between two factors? (i.e. myList[1] * myList[2])
