ram
ram
How we can close an opened excel file using JSL?
8 REPLIES 8
ian_jmp
Re: How we can close an opened excel file using JSL?
NamesDefaultToHere(1);
dt = Open("$SAMPLE_IMPORT_DATA/Fill Weights.xlsx");
Wait(3);
Close(dt, NoSave);
ram
ram
when you open .xlsx, is it .jmp or .xlsx ? i like to close a .xlsx file not
.jmp
You should see a JMP data table. If you are seeing excel opening a spreadsheet, something else is going on. If you open the .xlsx manually from JMP's file->open dialog, you'll land in JMP's import wizard which will help you do the first import. You can use the Source script in the JMP data table to repeat the process without going through the wizard.
ram
ram
hi ,
i do not want to open as jmp data table. how can i open as excel and close that excel using jsl?
When you Open() an Excel file in JMP, it is converted to a JMP file.  What is the reason you want the files to remain in Excel format?  The structure of a JMP data table is required for the various JMP Platforms to work with them.
ram
ram
we can use function web()
web() launches excel as a separate program, independent of JMP. JMP does not have a way to close the excel spread sheet.
ram
ram
I was looking for both functiuons. i found web() to open excel file by a clickable link.
i guess no function to close the excel file using JSL.
Thanks all for your contribution.
