bernie426
How to write a command on Formula-Character
I will like to know how to write a workable command using Formula-Character functionality.
For example, I have a column of character data that have data like leveled from Class 1.0 to Class 9.0.
I would like convert this information to another column that only show 1.0 to 9.0, how can I use the formula character function to write a command for this?
The other request I like to know is how can I change a column of character data to another statement in a new column.
For example, I have a character column of data showing sweet, tasty, sour,...and I would like to change it to be sweet-->Bin1, tasty-->Bin2, sour-->Bin3. How can I use the formula character to convert the sweet-->Bin1 in a new column.
Thanks,
10 REPLIES 10
jules
Re: How to write a command on Formula-Character
Hi bernie426,
To extract a piece of a your column you could use the Word() function, which takes two arguments: the first is which "word" to extract (you will enter a number here), and the second is the column with text you wish to extract from. There is a third, optional argument in which you can specify the delimiters that separate words, but in your case the default of a "space" will work. So, to use this, make a new formula column with Word(2,:Class)  (where :Class is whatever variable your original data is stored in).  For example (also in the attached dataset):
8049_Screen Shot 2015-02-13 at 1.23.26 PM.png8049_Screen Shot 2015-02-13 at 1.23.26 PM.png
This will take the second "word" which is just whatever is after the first space encountered, thus just the numbers.
For your second question I would use the match function (below). You can write this yourself, or use the column recode utility to write it for you. To do the latter, select the original column, then go to Cols > Recode. Specify what new values you wish your variable to have, then select "Formula Column" instead of "In Place."  JMP will make you a new column using the match function.
8048_Screen Shot 2015-02-13 at 1.23.20 PM.png8048_Screen Shot 2015-02-13 at 1.23.20 PM.png
You could use Cols > Recode in this same way for your first question, but if you have many levels using Word() will be faster than manually specifying the recoding.
I've attached an example dataset with these formulae.
I hope this helps!
julian
bernie426
Thanks a lots for the useful information Julinan.
Bernie
jules
You're welcome! I just read your initial post again and it occurred to me you might have been looking for a scripting solution rather than a column formula solution. If that is the case let me know and I can help you set this up through a script. You may have noticed in Col > Recode there is even an option to have JMP write the recoding as a script, so I would start there and we could adapt the code to use Word() to address your first question.
Julian
bernie426
Hi Julian,
So appreciate that you read my initial post again. Yes, it would be even better if there was having a script option since I am using this a daily based.
jules
Hi Bernie,
I'm glad I asked! There are a few ways you can approach this, depending on whether you would like to write a formula column, or write the actual values. Different circumstances call for one or the other, so I've included methods for both below.
To write the actual values:
Using Word() to extract just the numbers
//Make a new column
Current Data Table() << New Column("ClassNumberOnly", Character);
//stop table update until all changes are made, good for large tables
Current Data Table() << Begin Data Update;
//Apply changes to each row
For Each Row(
  :ClassNumberOnly = Word( 2, :Class )
// End "Data Update"
Current Data Table() << End Data Update;
Using Match() for recoding
//Make a new column
Current Data Table() << New Column("AttributeRecode", Character);
For Each Row(
  :AttributeRecode = Match( :Attribute,
  "Tasty", "Bin3",
  "Sweet", "Bin2",
  "Sour", "Bin1",
  :Attribute
To write a formula column:
//Make the formula column
Current Data Table() << New Column("ClassNumberOnly", Character,
  Formula(
  Word( 2, :Class )
Current Data Table() << New Column("AttributeRecode", Character,
  Formula(
  Match( :Attribute,
    "Tasty", "Bin3",
    "Sweet", "Bin2",
    "Sour", "Bin1",
    :Attribute
Hope this helps!
julian
bernie426
Hi Julian,
I got the “Match” script or formula working perfectly, and I love it so much.
However, I cannot get the “Word” function work on either formula or script.
The case I have is an existing column that is Character of “Class 1” to Class 9”, and I will like to have a new column beside it that only show the number (1 to 9) and it is still in Character/Attribute format.
Hence, based on the Word() script you wrote for me as an example, Do we need an input information for the mother column (Class1…Class 9) and use the Word() function?
Thanks,
Bernie
Using Words() to pull out just the numbers
//Make a new column
For Each Row(
pmroz
Try using the NUM function to convert the string number to an actual number.
a = "Class 9";
b = num(word(2, a));
jules
Hi bernie426
It sounds like you want to have the resulting column be numeric, is that right? If so, Peter's suggestion above is the right way to handle this. When you extract a piece of a string it stays a string, unless you tell JMP that you want to convert the string to be a number. Here is a completed script with the Num() function wrapped around the Word() function, and also one more change to make the new column be numeric when it is created.
Hope this works for you!
julian
//Make a new NUMERIC column
Current Data Table() << New Column("ClassNumberOnly", Numeric);
//The function below will look for a column named "Class"
//if the data are in column with a different name
//change :Class to be whatever the column name is, but
//be sure to retain the : since that lets JMP know you are
//referencing a column.
//this function also wraps the Word() function in Num()
//which will convert the character output to be a number
//allowing the resulting column to stay numeric
For Each Row(
  :ClassNumberOnly = Num( Word( 2, :Class ) )
bernie426
Hi Julian,
Actually, I would like to keep it as a character rather than converting them to numeric.
What I only would like is to get rid of the "Class " from  original "Class 9.0", and have only "9.0"showing.
I used the word (2, Class),  but it did not work out.
Thanks,
