Hi, I guess I didn't specify as such in my original question, but your solution did change the behaviour of my script since it copies the target script code into the new script. I wanted to keep the reference only to the original script. Here's the final script I'm using, maybe other people might find it useful.
scriptList = dt << Get Table Script Names;
For Each( {script_name}, scriptList,
If( (!Contains( script_name, "Run" ) & !Contains( scriptList, "Run " || script_name )),
Eval(
Substitute(
Expr(
dt << New Script(
"Run " || script_name,
w = Eval( dt << get table property( script_placeholder ) );
w << set window title( script_placeholder );
Expr(script_placeholder), Char(script_name)
