Nic
Nic
How to use correctly "Group Y by..." option in "Fit Y by X" platform?
Doctor
Jeff_Perkinson
Re: How do I get "Group Y by..." option in "Fit Y by X" platform (why it doesn't work)
Can you explain how it's not working for you? The Group By option will cause the Fit commands to perform one fit for each level of the grouping variable.
I used your data table and and ran Fit Y by X with myX and myY respectively.
Then I chose the "Group By..." option from the Bivariate menu and used Name as the Grouping variable.
2022-10-07_14-41-15.973.png2022-10-07_14-41-15.973.png 2022-10-07_14-41-25.746.png2022-10-07_14-41-25.746.png
Then fit a line and got this result:
2022-10-07_14-41-44.993.png2022-10-07_14-41-44.993.png 2022-10-07_14-41-54.477.png2022-10-07_14-41-54.477.png
-Jeff
First,  welcome to the community.
Use the Group by when running the platform Fit Y by X.  I have added the script to your data table.
Nic
Nic
What am I doing wrong?
Doctor
Jeff_Perkinson
-Jeff
