See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
How to use a variable with Outlinebox[ text()='text']
shampton82
Hey everyone,
I'm having an issue with some code.
MinParam=(report << XPath("//OutlineBox[text()='min']//OutlineBox[text()=mindist]//StringColBox[StringColBoxHeader[text()='Parameter']]"))<<get;
Here the variable is "mindist" and it equals "Normal 2 Mixtures".  However, I can't get it to work.
Any suggestions?
Steve
Re: How to use a variable with Outlinebox[ text()='text']
You could build it into the string
xpath_query = "//OutlineBox[text()='min']//OutlineBox[text()='" || mindist || "']//StringColBox[StringColBoxHeader[text()='Parameter']]";
MinParam = (report << XPath(xpath_query)) << get;
or maybe better is to use Eval Insert
xpath_query_template = "//OutlineBox[text()='min']//OutlineBox[text()='ยคmindistยค']//StringColBox[StringColBoxHeader[text()='Parameter']]";
xpath_query = Eval Insert(xpath_query_template, "ยค");
shampton82
Thanks @jthi !
That works!  I also realized that the name is different for the 3 mixtures in that it adds distribution to the end so that was probably the real issue but now I have more options to use.
For option 2, what are these?
"ยค"
Level XII
I use "non-default" starting/ending characters (used to indicate in which place the to be replaced variable is) as ^ appears too often in text (mostly it messes with anything using Regex). Eval Insert(string, <startDel>, <endDel>, < <<Use Locale(1) >) .
You can also use contains instead of text. Syntax is something like this (there is also starts-with in XPath and many more)
Report(dist) << XPath("//OutlineBox[contains(text(), 'Fitted Normal 3 Mixture')]//StringColBox[StringColBoxHeader[text()='Parameter']]");
If you need access to just single Fitted Normal 3 Mixture Distribution and string col box under it, it might be easier to use report subscripting instead of XPath. It also supports wild cards, but it is much more limited than XPath on what you can do (it is still useful from time to time), Get References to Display Box Objects Create a Reference by Subscripting / Wildcard String
dt = Open("$SAMPLE_DATA/Cytometry.jmp");
dist = dt << Distribution(Column(:CD8));
dist << Fit Normal 3 Mixture;
scb = Report(dist)[OutlineBox("Fitted Normal ? Mixture ?"), StringColBox("Parameter")];
scb << get;
