  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Neo
Neo
How to use Select Where () with Contains () to find partial matches in data table?
I have a list
myList  = {"Current_I20_", "Voltage_CIB_", "Capacitance_DIFF_", "Resistance_FURR_"};
and a data table with one of columns called Parameter with some row entries as
Current_I20_Stage2
Voltage_CIB_Stage3
Capacitance_DIFF_corner_Stage1
Resistance_FURR__side_Stage3
Using myList with Contains() to extract the full parameters names from the data table into a list. How to do this via JSL?
For a start, the following is not selecting anything in my data table. Where am I going wrong?
dt<< select where(Contains(mylist, As column (Parameter)));
mmarchandTSI
Re: How to use Select Where () with Contains () to find partial matches in data table?
This should work.
Clear Log();
dt = New Table( "Untitled 2",
	Add Rows( 6 ),
	Compress File When Saved( 1 ),
	New Column( "param",
		Character,
		"Nominal",
		Set Values( {"Current_I20_Stage2", "Voltage_CIB_Stage3", "Capacitance_DIFF_corner_Stage1", "Resistance_FURR__side_Stage3", "a", "b"} )
	New Column( "Group", Character, "Nominal", Set Values( {"A", "B", "C", "D", "E", "F"} ) ),
ToHideAndExcludeList = {"A", "D", "F"};
dt << Select Where( Contains( ToHideAndExcludeList, :Group ) );
sr = dt << Invert Row Selection;
sr << Hide and Exclude;
my_list = {"Current_I20_", "Voltage_CIB_", "Capacitance_DIFF_", "Resistance_FURR_"};
exrows = dt << Get Excluded Rows;
rows = dt << Get Rows Where( All( Contains( my_list, Word( [1 2], :param, "_" ) || "_" ), Contains( exrows, Row() ) == 0 ) );
vals = dt[rows, "param"];
11 REPLIES 11
Try adding empty square brackets after the closing parenthesis of your function call.
dt<< select where(Contains(mylist, As column (Parameter)[]));
Neo
Neo
@Mark_Bailey  Done, I do not get any errors but it does not select anything in the data table.
You need full matches when using contains with a list. You could use Word() to make your data table values be in same format as your list and then use contains (also convert the list to list of strings)
dt = New Table("Untitled 2",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("param",
		Character,
		"Nominal",
		Set Values(
rows = dt << Get Rows Where(Contains(my_list, Word([1 2], :param, "_") || "_"));
pmroz
Here's what I do when looking for partial matches.
dt = New Table( "TestRegex", Add Rows( 8 ),
	New Column( "TestCol", Character, "Nominal",
		Set Values(
			{"Current_I20_Stage2", "xyz", "Capacitance_DIFF_corner_Stage1", "lmnop",
			"aaa", "Voltage_CIB_Stage3", "Voltage_CIB_Stage3",
			"Resistance_FURR__side_Stage3"}
for (i = 1, i <= nitems(mylist), i++,
	match_rows = dt << get rows where(! is missing(regex(as column(dt, "TestCol"),
				mylist[i], "\0", ignorecase)));
	print(match_rows);
Neo
Neo
@jthi This works but does not seem to honour hidden and excluded rows in the data table dt
I want to exclude some rows based on another column in my data table as in JSL below. Perhaps this could be done within Get Rows Where ()?
clear log ();
	Add Rows(6),
	New Column("param",
		Character,
		"Nominal",
		Set Values(
	New Column("Group",
		Character,
		"Nominal",
		Set Values(
dt << Select Where( Contains(ToHideAndExcludeList, :Group) );
You could include the Row State as another condition.
Neo
Neo
@Mark_Bailey Thanks. Do you mean use Row State with Contains? Could I please have an example?
mmarchandTSI
This should work.
Clear Log();
	Add Rows( 6 ),
		Character,
		"Nominal",
Neo
Neo
@mmarchandTSI Many thanks. This works, but I would have preferred an approach where one could filter by row state ( as @Mark_Bailey suggested)  under Contains (). This would avoid any data table manipulation.
