Neo
Neo
How to use Select Where () with Contains () to find partial matches in data table?
I have a list
myList  = {"Current_I20_", "Voltage_CIB_", "Capacitance_DIFF_", "Resistance_FURR_"};
and a data table with one of columns called Parameter with some row entries as
Current_I20_Stage2
Voltage_CIB_Stage3
Capacitance_DIFF_corner_Stage1
Resistance_FURR__side_Stage3
Using myList with Contains() to extract the full parameters names from the data table into a list. How to do this via JSL?
For a start, the following is not selecting anything in my data table. Where am I going wrong?
dt<< select where(Contains(mylist, As column (Parameter)));
When it's too good to be true, it's neither
11 REPLIES 11
Re: How to use Select Where () with Contains () to find partial matches in data table?
Yes, combine multiple conditions with And() to match strings for rows that are not currently hidden or excluded. There is a complete explanation and plenty of examples here.
You could use !Excluded() and !Hidden() but Contains() seems to be doing some funny stuff in this case, so you have to manage around that, All() seems to work in this case
Clear Log();
dt = New Table("Untitled 2",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("param",
		Character,
		"Nominal",
		Set Values(
			{"Current_I20_Stage2", "Voltage_CIB_Stage3", "Capacitance_DIFF_corner_Stage1",
			"Resistance_FURR__side_Stage3", "a", "b"}
	New Column("Group", Character, "Nominal", Set Values({"A", "B", "C", "D", "E", "F"})),
ToHideAndExcludeList = {"A", "D", "F"};
dt << Select Where(Contains(ToHideAndExcludeList, :Group));
sr = dt << Invert Row Selection;
sr << Hide and Exclude;
dt << Clear Select;
my_list = {"Current_I20_", "Voltage_CIB_", "Capacitance_DIFF_", "Resistance_FURR_"};
rows = dt << Get Rows Where(All(Contains(my_list, Word([1 2], :param, "_") || "_")) & !Excluded() & !Hidden());
vals = dt[rows, "param"];
Edit:
Or some eval expr
rows = dt << Get Rows Where(Eval(EvalExpr((Contains(my_list, Expr(Word([1 2], :param, "_") || "_"))))) & !Excluded() & !Hidden());
