lala
Level IX
How to use Regex to intercept a specified range of content into a table?
Hello!
Assumption: The original data is obtained in the clipboard with consecutive empty lines at the end, and the rows that are not empty are not copied.
How to use the RE to intercept the content starting after the line containing the specified content and ending on the empty line.Copy to the new table.
For example: "Big Class.JMP"
And it says "ALFRED"
It get my new table.
Re: How to use Regex to intercept a specified range of content into a table?
In this simple case there is no need for regex and you can just get index from the list. If more complicated comparison is needed it should be fairly easy to build a loop to go through the list
dt << Add Rows(5, at end);
dt << Select columns("name");
Main Menu("Copy With Column Names", dt << Get Window Title);
clipb = Get Clipboard();
txt = Trim Whitespace(clipb);
l_all = Words(txt, "\!N");
break_str = "HENRY";
l_interested = Substr(l_all, Contains(l_all, break_str));
dt_new = New Table("table",
	Add Rows(N Items(l_interested)),
	New Column("col", Character, Nominal, Values(l_interested));
Many ways to handle this. Here is one idea using Data table subscripting
dt << Select columns({"name", "age", "sex"});
Main Menu("Copy", dt << Get Window Title);
// Substitute Into(txt, " ", "\!t"); // could replace spaces with tabs
// Using \!t for demo purposes
list_of_lists = Transform Each({line}, l_all, Words(line, "\!t"));
	Add Rows(N Items(l_all))
dt_new << Delete Column(1);
For(i = 1, i <= N Items(list_of_lists[1]), i++,
	dt_new << New Column("col" || char(i), Character, Nominal);
dt_new[0,0] = list_of_lists;
8 REPLIES 8
lala
Level IX
dt << Add Rows( 5, at end );
Wait( 0 );
Current Data Table() << Bring Window To Front;
Main Menu( "Copy With Column Names" );
txt = Get Clipboard();
lala
Level IX
  • Note: The data I'm actually working with is from the clipboard.
Thanks!
lala
Level IX
I Want to continue learning efficient code from the experts.
If the data OBTAINED from the clipBOARD HAS 3 columns per day and is separated by Spaces, not Tabs.
How to modify the code to get a table with three columns like this.
Thank jthi !
lala
Level IX
I'm still using JMP 14
This code is not running.
Thank jthi !
Change it to normal for-loop. Something like this should work
list_of_lists = {};
For(i = 1, i <= N Items(l_all), i++,
	Insert Into(list_of_lists, Eval List({Words(l_all[i], "\!t")}))
lala
Level IX
list_of_lists = {};
For(i = 1, i <= 3, i++,
	Insert Into(list_of_lists, Eval List({Words(l_all, " ")}))
