lala
Level IX
How to use JSL to set the color gradient of a column in text format by the value of a numeric column?
For example, the name column of Big Class.jmp automatically sets the color gradient of the name based on the value of the height column
It is required to be done in script.
Thanks!
16 REPLIES 16
lala
Level IX
Re: How to use JSL to set the color gradient of a column in text format by the value of a numeric column?
EmEditor
Lots of assumptions made in this script and it definitely isn't robust
m = 4;
Eval(
	Eval Expr(
		Column(dt, m) << set property(
			"Color Gradient",
			{"Green to White to Red", Range(
				{Expr(Col Min(Column(m))), Expr(Col Max(Column(m))), Expr(Col Mean(Column(m)))}
		) << Color Cell by Value(1);
// Lots of assumptions made in this solution
str = (dt << get as report) << get html;
// get just <table> and drop first row (headers)
l = Words(Regex(str, "<table.*</table>"), "\!N");
Remove From(l, 1,2);
Remove From(l, N Items(l));
// Get bgcolors
colors = {};
For Each({line}, l,
	str = Regex(line, "bgcolor=#(.*?)>", "\1");
	Insert Into(colors, str);
// Convert colors
// Option 1 (might work?)
jmp_colors = Transform Each({color}, colors, Hex To Number(color) * -1);
// Option 2
jmp_colors2 = Transform Each({color}, colors,
	r = Hex To Number(Left(color, 2));
	g = Hex To Number(Substr(color, 3, 2));
	b = Hex To Number(Right(color, 2));
	RGB Color({r,g,b});
// Set colors
// One row at the time
For Each Row(
	:name << Color Cells(jmp_colors[Row()], Row());
// Or create list of lists and use that
color_list = Transform Each({jmp_color, idx}, jmp_colors2,
	Eval List({jmp_color, idx});
Eval(EvalExpr(:age << Color Cells(Expr(color_list))));
lala
Level IX
be of no effect?
l = Words(Regex(str, ""), "\!N");
lala
Level IX
I used the sentence JSL didn't get it right, for some reason, JMP 17
Thanks!
// get just  and drop first row (headers)
Your regex pattern is incorrect
lala
Level IX
How do I modify this JSL to be a loop?
Thank you for your help!
For( j = 1, j <= N Row( dt ), j++,
	dt[j, "age"] << color_list( {j} )//?
You can get the idea from Transform Each I used or use the other method with For Each Row
