xjjrx
Custom Reference Lines between defined x-Axis points
I want to visualize data from production and want to implement reference lines to reflect the targets. The issue I face is, that the target changes due to product changes.
This means, I not just need to define the y-value of the reference lines, but also the x-values. I tried by simply adding lines in the code, which did not led to the needed lines in the graph:
Graph Builder(
	Size( 1524, 884 ),
	Variables( X( :prod_day ), Y( :Result ) ),
	Elements( Points( X, Y, Legend( 5 ) ), Smoother( X, Y, Legend( 6 ) ) ),
	Elements(
		Line( X( 0, 81 ), Y( 13.37, 13.37), Color( "Black" ), Line Style( "Solid" ) ),
		Line( X(82, 99), Y(12, 12), Color( "Black"), Line Style( "Solid"))
		Dispatch(
			"prod_day",
			ScaleBox,
			{Min( -0.5 ), Max( 134 ), Inc( 10 ), Minor Ticks( 0 )}
		Dispatch(
			"Result",
			ScaleBox,
			{Min( 2.75 ), Max( 7 ), Inc( 1 ), Minor Ticks( 1 )}
Is there a way, to add lines between two defined x-axis points?
I am using JMP Pro 17.0.
Thanks in advance!
Re: Custom Reference Lines between defined x-Axis points
You can use Graphic Scripts
gb = dt << Graph Builder(
	Size(525, 454),
	Show Control Panel(0),
	Variables(X(:weight), Y(:height)),
	Elements(Points(X, Y, Legend(3)))
fb = Report(gb)[FrameBox(1)];
fb << Add Graphics Script("Front",
	Description("Line"),
	Line([74 134], [55 68])
