Just for clarification,
Number( dt[Row(), Index( 11, 15 )] )
will not give you the same results as
sum(if(abs(As Column(11))>=0,1),if(abs(As Column(12))>=0,1),if(abs(As Column(13))>=0,1),if(abs(As Column(14))>=0,1),if(abs(As Column(15))>=0,1))
The first equation will give you the count of non blank(null) values, while the second equation gives you the count of non zero values.
Additionally, a simpler version of the second equation is:
Sum( As Column( 11 ) != 0, As Column( 12 ) != 0, As Column( 13 ) != 0, As Column( 14 ) != 0, As Column( 15 ) != 0 )
