lwx228
Level VIII
How to use JSL to color local cells by value?
For example, in the "weight" column of "Big class.jMP ", take the data in rows 1-10 and make the gradient color by data height, as in the Image.So can start and stop any color  want.
Re: How to use JSL to color local cells by value?
Here is a script that will color the column weight's first 10 rows in the data table.
names default to here(1);
dt=Open("$SAMPLE_DATA/big class.jmp");
// Set the gradient list of colors
colorList = {-2768895, -5530606, -6582759, -8094941, -9147350, -10462158, -11514567, -12237762,
-13344414, -14575206};
// Color first 10 rows
// find the range
weightMin= col min(if(Row()<=10,:weight,.));
weightMax= col max(if(Row()<=10,:weight,.));
weightInc= (weightMax-weightmin)/10;
// Loop across and set the colors
For(i=1,i<=10,i++,
	Bin=floor((:weight[i]-weightMin)/weightInc)+1;
	if(Bin>10,Bin=10);
	:weight << color cells( colorList[bin],i)
To understand all of the concepts behind the colors in JMP, you need to read the documentation in the Scripting Guide on Specifying Colors
pmroz
What OS and JMP version(s) are you using?  I'm using JMP 14 on Windows 10, 64-bit.
Try these steps:
  • Open Big Class
  • Right click on height > Column Properties > Color Gradient
  • Check "Color Cell by Value", then OK
  • You should end up with this:
If this still doesn't work you'll need to contact the JMP helpdesk.
26 REPLIES 26
lwx228
Level VIII
"Color scales" were not found on the script index.
  • Thanks!
// find the range
For(i=1,i<=10,i++,
	if(Bin>10,Bin=10);
lwx228
Level VIII
Thank Jim!
I searched the index and saw only this.
Where I can see a more complete color code?
Look in the Scripting Guide.......not just the Scripting Index
pmroz
You can also try color gradient.
dt = open("$sample_data\Big Class.jmp");
bmin = col min(dt:height);
bmax = col max(dt:height);
bavg = col mean(dt:height);
dt:height << set property("Color Gradient", {"Light Spectral", Range( {bmin, bmax, bavg} )});
dt:height << Color Cell by Value(1);
This will color the entire column.  You can use color cells for rows 11 to the end to remove the color.
lwx228
Level VIII
Thank pmroz!
Is your code complete?I didn't see any results when I ran it, and I didn't know how to perfect the code.Thanks for your help!
pmroz
You should see this:
pmroz
Here's how to only show the color gradient for rows 1-10.  Note that the min, max and mean are calculated on the entire column.  You can adjust that.
reset_rows = 11::40;
dt:height << color cells ("White", reset_rows);
lwx228
Level VIII
Thank pmroz!
Strange, I still don't see 1-10 lines of color here.Lines 11 to 40 are white.
