How to use JSL set the size and color of the title in the panel box?
Created:
May 5, 2023 04:52 AM
| Last Modified: Jun 10, 2023 1:55 PM(2967 views)
How to use JSL Set the size and color of the title in the panel box? I used set font in the panlbox, the font is not right, check the index also did not find. Thanks!
Most elements in JMP are not font-customizable, unfortunately. I believe that you don't have any direct control over the Panel box font, other than some system-wide preferences that can affect it.
That is correct. The protocol for the Panel Box object does not currently include any messages to change the font or its attributes. You can only change the title (i.e., the character string shown as the title).
