lwx228
Level VIII
How to use JSL form of "POST" WEB data?
After I learned to use JMP to download web page data, ga mother likes to use JMP to download web page data now, but it is more difficult to process the web page of POST.
Get expert help: how to download data using JSL in the following way:
POST http://listxbrl.sse.com.cn/companyInfo/showBalance.do HTTP/1.1
Host: listxbrl.sse.com.cn
Connection: keep-alive
Content-Length: 54
Accept: */*
Origin: http://listxbrl.sse.com.cn
X-Requested-With: XMLHttpRequest
Content-Type: application/x-www-form-urlencoded; charset=UTF-8
Referer: http://listxbrl.sse.com.cn/companyInfo/toCompanyInfo.do?stock_id=600007&report_period_id=5000
report_year=2018&stock_id=600007&report_period_id=5000
I can do it with VBA.
Ryan_Gilmore
Re: How to use JSL form of "POST" WEB data?
These lines of code,
query = Associative Array();
query["report_year"] = 2018;
query["stock_id"] = 600007;
query["report_period_id"] = 5000;
are used to construct the query parameter list in the URL, e.g.
In the original code I supplied, the code had
query["period_id"] = 5000;
which would have given an incorrect query parameter list of
report_year=2018&stock_id=600007&period_id=5000
Using example in the thread, you'd want something like:
request = HTTP Request(
	Url( "http://listxbrl.sse.com.cn/companyInfo/showBalance.do" ),
	Method( "POST" ),
	Form( Fields(query) )
request << Send;
The Form message has been there since the beginning.
It has Fields and Files sub parts to it. Both are associative arrays.
In the "Fields" case it's name/value pairs where the value can be either character or a List of characters.
In the "Files" case it's name/value pairs where the value can be either filename or a List of filenames.
If only "Fields" is used, then the request header is automatically set to application/x-www-form-urlencoded
If "Fields" and "Files" (or just "Files") is used, then the request header is automatically set to multipart/form-data.
I'll update the thread with this information, too.
14 REPLIES 14
lwx228
Level VIII
I searched for-
Method("POST")
in the help file 、but found no similar code.
lwx228
Level VIII
Below is the VBA code, can be downloaded to get the page data.
But I still haven't been able to convert it into JSL code.
Please give me help.Thank you very much!
VBA:
Sub Main()
    Dim strText As String
    With CreateObject("MSXML2.XMLHTTP")
        .Open "POST", "http://listxbrl.sse.com.cn/companyInfo/showBalance.do", False
        .setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
        .Send "report_year=2018&stock_id=600007&report_period_id=5000"
        strText = .responsetext
        Debug.Print strText
    End With
    Cells(1, 1) = strText
End Sub
Ryan_Gilmore
I think the following might be close to what you need,
request_headers = Associative Array();
request_headers["Content-type"] = "application/x-www-form-urlencoded";
	Method( "POST" ),
	Headers( request_headers ),
	QueryString( query )
lwx228
Level VIII
Thank Ryan_Gilmore !
This approach still hasn't worked.
It seems that this form of POST method, JMP application is not yet.
Ryan_Gilmore
Once the request has been created. you then need to issue the Send command, e.g.
data = request << Send;
If( request << IsSuccess,
    json_data = Parse JSON( data );
lwx228
Level VIII
My knowledge of the JMP approach is limited.
I can only imitate.Still no results.
Thank Ryan_Gilmore!
lwx228
Level VIII
get "DATA" of theta:
" <!DOCTYPE html PUBLIC \!"-//W3C//DTD XHTML 1.0 Transitional//EN\!" \!"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\!"> <html xmlns=\!"http://www.w3.org/1999/xhtml\!"> <head> <meta http-equiv=\!"Content-Type\!" content=\!"text/html; charset=utf-8\!" />
</p> </body> </html> "
Ryan_Gilmore
I notice that one of the parameters is incorrect. The code I suggested had "period_id" rather than "report_period_id" as shown in your original post. It's possible that may be contributing to the "500 Internal Server Error" message.
lwx228
Level VIII
I SEE.
