Saravana
How to use Graph boxes in the JMP Application builder
Hi all,
I am new to JMP. I am building a JMP application to read data from a JMP table and plot the data (Column 1 vs Column 2) in the graph box available in the JMP application. I was able to read the data from the table but not able to plot the graph in th graph box. I think I am not using proper script for graph box.
Can any one explain how to display graph in graph box for my use case?
12 REPLIES 12
Saravana
Re: How to use Graph boxes in the JMP Application builder
Hi cwillden
I solved the error.
I just used x = table:Name("Level") << Get Values; instead of x = table:Level << Get Value.
hogi
Level XIII
For a Graph Box in a Dashboard, is there a setting to restrict the displayed data points to the selection of the local Data Filter - or does the user have to control it via:
Names Default to Here(1);
New Window( "Data filter example",
	H List Box(
		Data Filter Context Box(
			H List Box(
				Data Filter Source Box(
					df = dt << Data Filter(
						Local,
						Add Filter( columns( :name ), Where( :name == {"CLAY", "DANNY", "DAVID", "EDWARD"} ) )
				dt << Graph Builder(
					Show Control Panel( 0 ),
					Variables( X( :height ), Y( :weight ) ),
					Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) )
				V List Box(
					Graph Box(
						X Scale( 50, 70 ),
						Y Scale( 60, 200 ),
						myValues = As List( dt[df <<Get Filtered Rows, {height, weight}] );
						For Each( {pos}, myValues,
							Print( pos );
							Circle( pos, 1 );
Boxes in Dashboard Builder and Application Builder do not really have added features that they do not already support via JSL.
