  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
JMP2021
How to create a new column with numerical number based on the unique grouping of column A
I have a table with Column A (char). I want to add a new column in number value which represents the grouping of column A. How to do this automatically? Column A has too many characters for me to manually group them.
column Anew column
kkk1
dd2
kkk1
cc3
3 ACCEPTED SOLUTIONS
WebDesignesCrow
Re: How to create a new column with numerical number based on the unique grouping of column A
May be can use Cols --> Utilities --> Labels to Code (it automatically assign a code based alphabetical order)?
Then you create new column using below formula;
:new column << Set Formula( Col Stored Value( :Column A ) );
JMP2021
thank you. It worked.
JMP2021
one more question is that the code is sequential given. I wonder if there is a way to assign the number based on the highest occurrence in column A.
WebDesignesCrow
JMP2021
JMP2021
WebDesignesCrow
to assign the number based on highest occurrence in column A need some work around.
1. create a summary table by group, "Column A" --> sort N column "Descending"
2. add formula column: new result = Row ();
3. join both tables or update main table to match "Column A".
If you're using scripting, it needs few lines as below;
// → Data Table( "Untitled" )
New Table( "Untitled" );
// Data table summary
// → Data Table( "Untitled By (Column A)" )
Data Table( "Untitled" ) << Summary(
Group( :Column A ),
Freq( "None" ),
Weight( "None" )
// Sort data table
Data Table( "Untitled By (Column A)" ) << Sort(
	By( :N Rows ),
	Replace Table,
	Order( Descending )
// New column: new result
Data Table( "Untitled By (Column A)" ) << New Column( "new result",
	Numeric,
	"Continuous",
	Format( "Best", 12 ),
        Formula( Row() )
// Update data tables
Data Table( "Untitled" ) << Update(
	With( Data Table( "Untitled By (Column A)" ) ),
	Match Columns( :Column A = :Column A )
hope it helps.
