bernie426
How to use Dif/Lag function by Column group
Hi JMP community folks,
I have a data table with four columns as Box, iClass, BinPos, and Slot.   iClass means 24 level of products, BinPos means the Box location in the sorting equipment and Slot indicated which slot position the product be placed in the box. The Box is designed to hold a max quantity of 100 product, after that a new empty box would be placed in. In order to check the product is be placed in the right box and the Slot increment is exactly by "1" (because sometime I do manually observed the slot increment increase >1 or increment=0, which meant the placing machine having issues),I tried to use the dif/lag function to check the increment. However, the dif/lag formula is not allowing me the add a function to group by column of Box. The Box is actually the unique identifier.
A formula like Dif(:Slot,1) can tell me the difference b/w a certain with respect to the row before it. However, the rows are mixed by with different Box because of difference level of product belong to iClass column.
I am hoping to have a formula like Dif(:Slot, 1, :Box) to work out. Can any expert provide some clues to work this out? A example table is attached for investigation.
Many Thanks in advance
BoxiClassBinPosSlot
72813_2111164
73213_215152
73213_215153
73213_215154
73213_215155
73213_215156
73213_215157
73213_215158
73214_214141
73214_214142
73214_214143
73214_214144
73214_214145
73214_214146
73213_215159
73214_214147
73213_2151510
73213_2151511
73213_2151512
73213_2151513
73213_2151514
73213_2151515
73214_214148
Re: How to use Dif/Lag function by Column group
The example is a formula for a new table, not a JSL standalone script.  Create a new column, and paste the formula into the formula for the column, and it will generate the incremental values you want.
11 REPLIES 11
mpl34
Can you sort by :Box and then apply the formula after checking that :Box==Lag(:Box,1)?
If the absolute order of the original data is not important, sorting the data and using the Dif function will work.  However, here is a formula that you can use that will calculate the increment without having to sort the data.
i = Row();
allrows = Current Data Table() << get rows where( :Box == :Box[i] );
If( Loc( As List( allrows ), i )[1] == 1,
       1,
       slot[allrows[Loc( As List( allrows ), i )[1]]] - slot[allrows[(Loc( As List( allrows ), i )[1])-1]]
bernie426
Hello Jim,
I tried to run the script you made (just copy and pasted the entire script), however, I cannot see anything change in the data table and no New Column to generate.
I tried to make a new column with your script but nothing work either.
This is what the script I tried to run,
i = Row();
allrows = Current Data Table() << get rows where( :Box_ID == :Box_ID );
allrows<< New Column("Test", Numeric, Continuous, Formula(If( Loc( As List( allrows ), i )[1] == 1,
       1,
Regards,
bernie426
Hi Jim,
Thanks for the help. Actually, I have more than 60,000+ rows in a single daily table if I run a formula you provide it would take a fairly long time.
Would it be quicker if I sort the data first then run the formula?
Btw, is there a way for jmp a count the time it run for a script or formula?
Regards,
With that many rows, using the sort method would be faster.  Below is the method that I use to find the time a script takes:
start = today();
   the script or part of a script you want to find the timings on
show( today() - start );
pmroz
If you need more accuracy in the timing, @msharp noted in a recent post:
Today() is only accurate to the second, Tick Seconds() is accurate to 1/60 of a second, and HP TIME() is accurate to the microsecond.
Here is a rework of the previous formula.  This formula works with JMP 14
If( Row() == 1,
	dt = Current Data Table()
i = Row();
holdBox = :Box;
allrows = dt << get rows where( holdBox == :Box[i] );
	1,
	:Slot[allrows[Loc( As List( allrows ), i )[1]]] - :Slot[allrows[Loc( As List( allrows ), i )[1] - 1]]
miguello
Jim,
This is a very valuable workaround since it provides a functionality of a non-existen formula ColLag(); :)
However, I see it's been quite a while since you posted this workaround. JMP 14 nowadays doesn't like how it's written. It says Get Rows Where is an unknown function and it says that using Current Data Table() in formulas is not stable.
Is there any newer version of this workaround?
Thanks,
M.
