lala
Level IX
How to trigger “OK” button with Enter key in JSL ?
I created a dialog window with a text input field and an OK button.
Currently, the next step can only be triggered by clicking the OK button with the mouse.
I would like to know:
Is it possible in JSL to allow pressing the Enter key to trigger the OK button (i.e., proceed to the next step) instead of clicking it manually?
If this is not supported, what is the recommended or standard workaround in JMP?
Re: How to trigger “OK” button with Enter key in JSL ?
ex = New Window("",
	<<modal,
	Border Box("",
		teb = Text Edit Box("", << Set Function(Function({this},
			btn << Click(1);
		, <<Set Width(300))
	Panel Box("",
		H List Box(
			btn = Button Box("OK",
				ng = teb << get text;
Write();
"Recommended" workaround depends on what you are trying to do. << Set Function + << Click() is one option but it will trigger when the input is committed not just on enter press.
lala
Level IX
ex=New Window("",<<modal,Border Box("",teb=Text Edit Box("",<<Set Width(300))),Panel Box("",H List Box(Button Box("OK",ng=teb<<get text))));
ex = New Window("",
	<<modal,
	Border Box("",
			btn << Click(1);
		, <<Set Width(300))
	Panel Box("",
		H List Box(
Write();
