Neo
Neo
How to supply argument to delimiter in combine columns ()?
The following does not work
Names Default To Here (1);
// Combine columns
dm = ".0";
Data Table( "myTable" ) << Combine Columns(
	columns( :Col1, :Col2 ),
	Column Name( "ID" ),
	Delimiter(dm)
  //Delimiter ("dm")
But writing the argument to Delimiter directly as
Delimiter(".0")
works. How to supply argument to the delimiter from outside?
When it's too good to be true, it's neither
Jeff_Perkinson
Re: How to supply argument to delimiter in combine columns ()?
The Combine Columns message is doing the same as Cols > Utilities > Combine Columns.
Combine Columns doesn't support any conditionalizing.
Instead, I'd create a new column with a formula to concatenate your other columns as you desire.
Here's what the formula would look like in the Formula Editor.
And here's the JSL to create it.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
// Combine columns
dm1 = ":";
dm2 = "-";
Eval(
	Substitute(
			Expr(
				dt << New Column( "ID",
					Character,
					"Nominal",
					Formula( :name || If( :age <= 13, d1, d2 ) || Char( :age ) ),
		Expr( d1 ), dm1,
		Expr( d2 ), dm2
-Jeff
Jeff_Perkinson
This happens because JMP doesn't evaluate arguments to arguments in messages.
You can use Substitute to substitute in the value of dm.
// Combine columns
dm = ":";
Eval(
	Substitute(
			Expr(
				dt << Combine Columns(
					columns( :name, :age ),
					Delimiter( d )
		Expr( d ), dm
-Jeff
Neo
Neo
@Jeff_Perkinson Thanks. In this case, how to script, if I have a condition on the delimiter -  e.g.  delimiter = ".0" if : age <13 and delimiter = ".1", otherwise.
Jeff_Perkinson
// Combine columns
dm1 = ":";
dm2 = "-";
Eval(
	Substitute(
			Expr(
					Character,
					"Nominal",
		Expr( d1 ), dm1,
		Expr( d2 ), dm2
-Jeff
