Neo
Neo
How to supply argument to delimiter in combine columns ()?
The following does not work
Names Default To Here (1);
// Combine columns
dm = ".0";
Data Table( "myTable" ) << Combine Columns(
	columns( :Col1, :Col2 ),
	Column Name( "ID" ),
	Delimiter(dm)
  //Delimiter ("dm")
But writing the argument to Delimiter directly as
Delimiter(".0")
works. How to supply argument to the delimiter from outside?
Jeff_Perkinson
Re: How to supply argument to delimiter in combine columns ()?
The Combine Columns message is doing the same as Cols > Utilities > Combine Columns.
Combine Columns doesn't support any conditionalizing.
Instead, I'd create a new column with a formula to concatenate your other columns as you desire.
Here's what the formula would look like in the Formula Editor.
And here's the JSL to create it.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
// Combine columns
dm1 = ":";
dm2 = "-";
Eval(
	Substitute(
			Expr(
				dt << New Column( "ID",
					Character,
					"Nominal",
					Formula( :name || If( :age <= 13, d1, d2 ) || Char( :age ) ),
		Expr( d1 ), dm1,
		Expr( d2 ), dm2
-Jeff
Jeff_Perkinson
This happens because JMP doesn't evaluate arguments to arguments in messages.
You can use Substitute to substitute in the value of dm.
// Combine columns
dm = ":";
Eval(
	Substitute(
			Expr(
				dt << Combine Columns(
					columns( :name, :age ),
					Delimiter( d )
		Expr( d ), dm
-Jeff
Neo
Neo
@Jeff_Perkinson Thanks. In this case, how to script, if I have a condition on the delimiter -  e.g.  delimiter = ".0" if : age <13 and delimiter = ".1", otherwise.
Jeff_Perkinson
// Combine columns
dm1 = ":";
dm2 = "-";
Eval(
	Substitute(
			Expr(
					Character,
					"Nominal",
		Expr( d1 ), dm1,
		Expr( d2 ), dm2
-Jeff
