MuttonChops
How to summarize by variable column names
I have a table with variable numeric, continuous column names.  I need to get the mean of each column, grouped by a different column.  The script below shows what I'm trying to do and it makes a generic table that works for this purpose.  I'm getting hung up on the "Mean(ColNames)" line because it can't seem to process that.
If I replace "Mean(ColNames)" with "Mean(:Col2, :Col3)" or "Mean(:Name("Col2"), :Name("Col3"))" then it works but obviously doesn't meet my need of being able to use variable columns.  Am I close or way off?
// Make a table to work with nr = 20; nc = 3; dt = NewTable("Random_Table"); For(c=1, c<=nc, c++, dt << NewColumn("Col"||Char(c), Numeric, Continuous, Formula(RandomInteger(1, 10))); ); dt << AddRows(nr); Column(1) << Data Type(Character); //Get column names for the numeric continuous columns ColNames = dt << Get Column Names(Numeric, "Continuous"); dt << Summary( Group(:Col1), Mean(ColNames), statistics column name format( "column" ) );
Re: How to summarize by variable column names
Put and Eval() around the columns list and it will work
names default to here(1);
dt=open("$SAMPLE_DATA\big class.jmp");
dt << Summary(
		Group(:sex),
		Mean(eval(ColNames)),
dt << Summary(
		Group(:sex),
