gene
Stand alone application.
Is there any way in JMP to build appications that can be run by folks without JMP?  Something like a .exe.
Gene
vince_faller
Re: Stand alone application.
You can save premade reports to interactive HTML.  What are you trying to run?
Vince Faller - Predictum
gene
I'm trying to perform table manipulations to excel data.  In particular, a table split.  Real easy in JMP but a pain in excel since I have no DB tools that I'm aware of.  So I'd like to write a JSL script to read in an excel file, manipulate it, and then export it.  But my team doesn't have JMP...just me.
Gene
So, now you know why people use JMP and not Excel.  That should give you some justification for those other folks to get JMP.
No, each user needs to have a copy of JMP.
Are you running JMP 13?  If so you can select "Create Web View" under view.  Similar to what Vince Faller recommended, but different enough that you might want to give it a try.
