AlphaPony501
How to stack columns?
I have a data set with 22 subjects' active and placebo sides been tested for 4 times at 0w, 4w, 8w and 12w. Now I want to stack those columns of data (Active 0W, 4W, 8W,12W and Placebo 0W, 4W, 8W,12W)into one result column and also create two columns named Active/Placebo and Time to accurately describe each subject's result. I have attached the data table that I have and also the data table that I want to make. How do I do it?
Re: How to stack columns?
Besides using formulas, you can also split the Label column with following:
  1. Select Label Column
  2. Go to Text to columns in Cols / Utilities / Text to Columns...
  3. Use space as delimiter
  4. Delete Label column and rename the columns
Use
     Tables=>Stack
to stack the columns
Then create 2 new columns using these 2 formula.  Both columns should be defined as character columns.
Foe the Acrive/Placebo column
word(1, :label, " ");
For the time column
word(2, :label, " ");
AlphaPony501
Thank you very much for helping out!!!!! It worked!!
