arawlings
How to specify placement of JPEGs in PowerPoint
Hello!
I have learned how to automatically create, insert & update JMP graphs into PowerPoint via jsl script (see below script & reference). Now, I want to be able to specify a couple more items regarding these graphs:
1. WHERE on the PowerPoint slide it is to be
2. add a picture border to the graph in the PowerPoint slide
Here is my current script, which virtually opens the data, makes the graph, saves it, inserts it into PPoint, and then opens the PPoint.
dt = Open( "Blood_Pressure_Testing.jmp", invisible );
biv = dt << Graph Builder(
	Size( 826, 596 ),
	Show Control Panel( 0 ),
	Variables( X( :Subject ), Y( :Dose ), Color( :BP 8M ) ),
	Elements( Points( X, Y, Legend( 19 ) ) ),
	Local Data Filter( Close Outline( 1 ) ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				19,
				Properties(
					0,
					{gradient( {Color Theme( "Jet"(1) ), Discrete Colors( 1 )} )},
					Item ID( "BP 8M", 1 )
				Properties( 1, {Marker( "Filled Diamond" )}, Item ID( "Dose", 1 ) )
		Dispatch( {}, "graph title", TextEditBox, {Set Text( "XXXXXXX" )} )
Report( biv )[Outline Box( 1 )] << Set title( "This is my title" );
//test comment - this works
Report( biv ) << journal;
biv << close window;
jour = Current Journal();
jour << Save Presentation( "<path to save>" );
Open( "<path to PowerPoint" );
Thanks for the help!
Re: How to specify placement of JPEGs in PowerPoint
You can see the easy options you have available from Scripting Index (search for presentation) or from JMP Help. You might be able to do what you want, by building a custom window and saving that as an image to the powerpoint.
Usually I just use JMP to create report images and then I have Python script (parametrized) which I call using Run Program to create my powerpoint from those images (I don't use JMP's Python Integration as it, is in my opinion, a nightmare to get working).
