tLerman
How to sort the data table within an application?
I've written a fairly complex JSL application using the JMP Application Builder. The application launcher prompts the user for column selections and then I sort the data by the chosen columns before continuing with processing and visualizations.
If the data set has dependent open windows, I need to give the user the option to continue without sorting (the data was likely pre-sorted) or exit the script to let the user deal with the dependent windows.  To this end, I've created the following function:
sortThisData = Function ({dt},
	try( dt << Sort (By( Column(snCol), Column(dtCol)), Replace Table) ,
	/* IF thrown */
	if (contains(exception_msg[1], "JMP cannot replace the existing table"),
			ex = New Window( "Alert", <<Modal, <<Return Result,
				V List Box( H List Box( "Set this value",
					fontobj = text = Text Box( "JMP cannot replace the existing data table because open report windows depend on the previous ordering." )),
					Text Box(""),
						//H List Box( Button Box( "Continue Without Sorting" ), Button Box( "Cancel Script" ), Button Box("Create New Sorted Data Table") ) )
						V List Box (rb = Radio Box( {"Continue Without Sorting",
										"Cancel Script",
										"Create New Sorted Data Table"} ) );
		if (ex["rb"] == 1, /*Continue without sorting*/,
			ex["rb"] == 2, /*Stop script*/ (thisModuleInstance << Get Box) << Close Window; stop(),
			ex["rb"] == 3, /* New data table */ dt =  Sort (By(Column(snCol), Column(dtCol)), invisible)
	return (dt);
However, it seems that the application itself counts as a dependent open window! I can't sort the data even if no other windows are open.
How can I circumvent this issue and sort my data? I have moved the timing of calling my SORT function, but it needs to happen after the OK button on the launcher was pressed and before the processing/visualizations are done.
Any suggestions?
Re: How to sort the data table within an application?
I'm not sure I understand your question correctly, it seems that your script does not contain some character (")" in line 2 and "<<").
sortThisData = Function( {dt},
	Try( newdt = dt << Sort( By( Column( snCol ), Column( dtCol ) ), Replace Table ),  );
	/* IF thrown */
	if(contains(exception_msg[1], "JMP cannot replace the existing table"),
			<<Modal,
			<<Return Result,
			V List Box(
				H List Box(
					"Set this value",
				Text Box( "" ),
				V List Box(
					rb = Radio Box(
						{"Continue Without Sorting", "Cancel Script",
		If(
			ex["rb"] == 2, /*Stop script*/ (thisModuleInstance << Get Box) << Close Window;	Throw();,
			ex["rb"] == 3, /* New data table */ newdt = dt << Sort( By( Column( snCol ), Column( dtCol ) ), invisible )
	If(ex["rb"]==3, Return( newdt ), Return( dt ););
tLerman
Not sure what you mean by missing characters. But in any case, the issue is the same even if the call to the function above is replaced with a simple Sort Table:
DataTable1 << Sort (By( Column(snCol), Column(dtCol)), Replace Table);
I get the following alert, even though the only open window for DataTable1 is the application that called the Sort function.
I'm sorry that I have misunderstood what you want to do. It seems that it is not easy to sort a data table in Application Builder.
It is not a smart solution, you can copy a data table first and then sort the data table. It creates another data table, you should close a table when it is not used.
original_dt = Current Data Table();
dt =  original_dt << Subset( All rows, Selected columns only( 0 ), Link to original data table( 0 ), invisible );
dt << Sort( By( Column( dt, snCol ), Column( dt, dtCol ) ), Replace Table )
