lehaofeng
How to solve the problem that distribution commands need specification limit confirmation when the system is Chinese?
Why is it that my distribution command asks for no capability analysis, but when I run this code it still asks me to confirm that a capability analysis is performed.
There is no confirmation window when the system is in English, but there is when it is in Chinese. How to solve it, thanks!
dt2 = New Table( "x", New Column( "y", set values( 1 :: 32 ) ) );
Column( dt2, 1 ) << Set Property(
	"Spec Limits",
	{LSL( 1 ), USL( 32 ), Target( 16 ), Show Limits( 1 )}
nw = New Window( "distribution window",
	hb = H List Box(
		obj2 = dt2 << Distribution(
			Stack( 1 ),
			Continuous Distribution(
				Column( :y ),
				Process Capability( 0 ),
				Horizontal Layout( 1 ),
				Vertical( 0 )
			Histograms Only,
			Automatic Recalc( 1 )
Re: How to solve the problem that distribution commands need specification limit confirmation when the system is Chinese?
This stounds like a bug.  I suggest that you contact JMP Support.
lehaofeng
Okay, thanks.
