Do you have both the rows labeled as well as the column label turned on? You should see yellow label symbols as row states and next to the column with the values you wish to label in the left side columns panel. For example, I want to label all the US States by the percentage of high school graduates.
Steps:
-Rows menu>Row Selection>Select All Rows
-Once all the rows are selected, go to the Rows menu>Label
-Right Click on the column with the values I want to label by and select Label
-Olivia
