jsluser
How to set the value of a cell using character data stored in a variable?
Hi everyone,
I want to take the character value of a certain cell and transfer it over to 18 rows in a new data table.
I am having issues with the variables col1, col2, and col3 since their data type is character and only contains a single cell value. I cannot find a way to use this variable to populate rows 1-18 of my new table.
Here is a small sample of my code:
col1 = Column(dt,"PCMTest-A")[12::12];
col2 = Column(dt,"PCMTest-A")[13::13];
col3 = Column(dt,"PCMTest-A")[10::10];
col4 = Column(dt,"PCMTest-A")[39::56];
dt2 = NewTable("Result",
Add Rows(18),
NewColumn("Lot Name", Character, Values(col1)),
NewColumn("Wafer Name", Character, Values(col2)),
NewColumn("Mask", Character, Values(col3)),
NewColumn("X", Character, Values(col4)),
Any suggestions?
ih
Super User (Alumni) ih
Re: How to set the value of a cell using character data stored in a variable?
It looks like you just need to either repeat the value when setting values in the new column, or use the value in a formula.  Here is an example:
Names default to here( 1 );
dt1 = New Table( "Input",
	Add Rows( 3 ),
	New Column(
		"Column 1", Character, "Nominal",
		Set Values( {"a", "b", "c"} )
val1 = Column( dt1, "Column 1" )[1];
val2 = Column( dt1, "Column 1" )[2];
vals123 = Column( dt1, "Column 1" )[1::3];
dt2 = New Table( "Output",
	Add rows( 3 ),
	New Column( "Column 1", Character, "Nominal", Set Values( vals123 ) ),
	New Column( "Column 2", Character, "Nominal", Set Values( repeat( {val1}, 3 ) ) ),
	New Column( "Column 3", Character, "Nominal", Formula( val2 ) )
ih
	Add Rows( 3 ),
	New Column(
	Add rows( 3 ),
