CompleteLeopard
How to set spec limits color
Hi, JMPer I have used JSL to load spec limits into column Properties. But when generate graph or distribution charts, the spec limits' color is bule.
My question is:
1.How to change the colors to red and line to dot?
2.I used chinese vision, how to change it to english?
10 REPLIES 10
Victor_G
Re: How to set spec limits color
Hi @Gabogom,
To create a range of color in any graph, right-click on the Y axis, choose "Axis Settings", check the box "Allow ranges" and specify the min and max values with the color associated to the range:
Once you click on OK, the range color can be seen in the Prediction Profiler (or any other graph you want to customize):
Hope this answer will help you,
Victor GUILLER
