How to set row in which data starts based on keyword
Agustin
Hi, I'm trying to adapt this script:
// Import Excel file: file.xls
// → Data Table( "Results" )
Open(
	"$DESKTOP/JMP test/file.xls",
	Worksheets( "Results" ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Headers Start on Row( 51 ),
		Data Starts on Row( 52 ),
		Data Starts on Column( 1 ),
		Data Ends on Row( 0 ),
		Data Ends on Column( 0 ),
		Replicated Spanned Rows( 1 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 1 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
however instead of setting these parameters
I would like to check for the keyword "Start" in column 1, the row where "Start" is would be the Headers and the one after would be where the data starts.
Is there an easy way to do this?
I am putting together a script that opens several spreadsheets that are similar and then stacks them, but the row at which the data starts varies from spreadsheet to spreadsheet as they are automatically produced by lab equipment.
Thank you
Re: How to set row in which data starts based on keyword
There is not a "simple" way to do this, however, it is not overly complicated either.
  1. Each table will have to be read twice
    1. First, open the table indicating there is only one column, and it is delimited by the Line Feed character at the end of each line.
  2. Loop through the data table until the word "Start" is found.
    1. Save the Row number
  3. Delete the current data table
  4. Reopen the data table, reading it using your above parameters, with the Header Start and Data Start values set based upon the saved Row Number
Agustin
I'm only just starting using JSL and don't really know how to do that. Is there a documentation guide for JSL?
The Scripting Guide, which documents JSL(Jmp Scripting Language) is available in the JMP Documentation Library, found under  the Help pull down menu.
