Ted
Ted
How to set format for Distribution platform output?
Analyze=>Distribution
gives (by default) the following format:
Level Count Prob
1    4    0,03846
2   32   0,30769
3   57   0,54808
4   11   0,10577
Total  104  1,00000
but I need so:
Level Count Prob
1    4     3,8%
2   32   30,8%
3   57   54,8%
4   11   10,6%
Total  104  100,0%
It's easy to obtain if call (by double-clicking on it):
"Column Numeric Format".
OK! But it works for ONE variable! But I have MANY variables! How to set this format for all (in JMP v10)?
Files => Preferences=> ???
(or in some other way...?)
Re: How to set format for Distribution platform output?
The column in the table displayed is a Probability, therefore it is displayed properly.  If you change it to a percent, then you should also change the column header from "Prob" to "Percent".
There is not an option in the platform to change the format, however, in JSL
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
dis = dt << Distribution( Nominal Distribution( Column( :sex ) ) );
Report( dis )["Frequencies"][Table Box( 1 )][Number Col Box( 2 )] <<
set format( "Percent", 7, 2 ) << set heading( "Percent" );
Ed,
I am replying to your direct email to me, because your question to me was something that I believe others may find useful.  The direct emails are not available for searching by the general user community.
Here is my response to your direct email to me, which said:
Jim, sorry, I have 100 columns name(original) in my data file (names go in a row), I bring some of them:
1.1	1.2	1.3	1.4.1	1.5.1	1.5.2	1.5.3	1.5.4	1.5.5	1.5.6	1.5.7	1.5.8
I try list them using comma as separator in your script (but it does not work)... Ed
dt = Open( "F:/R/data/donor.jmp" );
dis = dt << Distribution( Nominal Distribution( Column( : 1.1, 1.2, 1.3, etc. ) ) );
set format( "Percent", 7, 1 ) << set heading( "Percent" );
The code you specified to create the distributions is incorrect, and additionally, the code required to handle multiple distributions forces a change in the code required to pass through all of the outputs to change the Frequencies tables
dt = New Table( "All Nominal",
	Add Rows( 40 ),
	New Column("1.1",
	Character,
		"Nominal",
		Set Values(
			{"KATIE", "LOUISE", "JANE", "JACLYN", "LILLIE", "TIM", "JAMES", "ROBERT",
			"BARBARA", "ALICE", "SUSAN", "JOHN", "JOE", "MICHAEL", "DAVID", "JUDY",
			"ELIZABETH", "LESLIE", "CAROL", "PATTY", "FREDERICK", "ALFRED", "HENRY",
			"LEWIS", "EDWARD", "CHRIS", "JEFFREY", "MARY", "1.1", "ROBERT",
			"WILLIAM", "CLAY", "MARK", "DANNY", "MARTHA", "MARION", "PHILLIP",
			"LINDA", "KIRK", "LAWRENCE"}
	New Column("1.2",
	Character,
		"Nominal",
		Set Values(
			{"12", "12", "12", "12", "12", "12", "12", "12", "13", "13", "13", "13",
			"13", "13", "13", "14", "14", "14", "14", "14", "14", "14", "14", "14",
			"14", "14", "14", "15", "15", "15", "15", "15", "15", "15", "16", "16",
			"16", "17", "17", "17"}
	New Column("1.3",
	Character( 1 ),
		"Nominal",
		Set Values(
			{"F", "F", "F", "F", "F", "M", "M", "M", "F", "F", "F", "M", "M", "M",
			"M", "F", "F", "F", "F", "F", "M", "M", "M", "M", "M", "M", "M", "F",
			"F", "M", "M", "M", "M", "M", "F", "F", "M", "F", "M", "M"}
	New Column("1.4",
		Character,
		"Nominal",
		Set Values(
			{"59", "61", "55", "66", "52", "60", "61", "51", "60", "61", "56", "65",
			"63", "58", "59", "61", "62", "65", "63", "62", "63", "64", "65", "64",
			"68", "64", "69", "62", "64", "67", "65", "66", "62", "66", "65", "60",
			"68", "62", "68", "70"}
	New Column("1.5",
	Character,
		"Nominal",
		Set Values(
			{"95", "123", "74", "145", "64", "84", "128", "79", "112", "107", "67",
			"98", "105", "95", "79", "81", "91", "142", "84", "85", "93", "99",
			"119", "92", "112", "99", "113", "92", "112", "128", "111", "105", "104",
			"106", "112", "115", "128", "116", "134", "172"}
// Run the distributions
	Nominal Distribution( Column( :Name( "1.1" ) ) ),
	Nominal Distribution( Column( :Name( "1.2" ) ) ),
	Nominal Distribution( Column( :Name( "1.3" ) ) ),
	Nominal Distribution( Column( :Name( "1.4" ) ) ),
	Nominal Distribution( Column( :Name( "1.5" ) ) )
// Change the tables
// Because of Your column names(this is a JMP bug I believe), we have
// to use a direct reference to the Outline Box number.  See below where
// if the column names were not of the form 1.1, 1.2, 1.3 etc. a better
// reference could be made
For( i = 2, i <= N Col( dt ) * 2, i++,
	Report( dis )[Outline Box( i )]["Frequencies"][Table Box( 1 )][Number Col Box( 2 )] <<
/*For( i = 1, i <= N Col( dt ), i++,
	Report( dis )[column(dt,i)<<get name]["Frequencies"][Table Box( 1 )][Number Col Box( 2 )] <<
Ted
Ted
Oh, Many Thanks! I will try...
P.S. It's strange, why I can't put "kudos" (stopped working)?!
Concerning the Kudos, I would try changing your browser to Chrome
Ted
Ted
I always use Chrome
Ed,
	Add Rows( 40 ),
	New Column("1.1",
	Character,
		"Nominal",
		Set Values(
	New Column("1.2",
	Character,
		"Nominal",
		Set Values(
	New Column("1.3",
	Character( 1 ),
		"Nominal",
		Set Values(
	New Column("1.4",
		Character,
		"Nominal",
		Set Values(
	New Column("1.5",
	Character,
		"Nominal",
		Set Values(
Ted
Ted
Grandiose! Thank you very much for your help!
