Thank you very much for your effort to elaborate the question!
What you observed is the behavior by design. And you won't be able to see Likelihood Confidence Intervals in profilers.
The reason is due to computation cost and usability. Calculating Likelihood Confidence Intervals is computationally intensive.
It is by design not to show Likelihood confidence intervals in the profiler, or the profiler will be unusable. That is true for all profilers in reliability platforms. And probably true elsewhere. I am glad that you found the places to get Likelihood confidence intervals for predictions. And you shall see when you have enough failure observations, the two types of intervals are rather close. If you have fewer failures, Likelihood confidence intervals are more trustworthy, and you should be alerted by the wide Wald intervals in the profiler first.
Thank you very much for your answer. It is a bit unfortunate though that we cannot have this feature due to it being the computationally heavy operation.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '606695' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '606695') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '606695') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
