Hanyuri
How to set JMP v11 as default launcher
Hi all,
I'm using both JMP v11 and v12 and my JMP default launcher is v12. Recently I have an add-in which is only available for JMP v11. However, when I installed the add-in, it automatically launched JMP v12 instead of JMPv11. Would you please share how to switch the default launcher from JMPv12 to v11 and backwards?
Re: How to set JMP v11 as default launcher
Start up the version of JMP you want to run
Go to
     Files==>Preferences==>Windows Specific
Click on the button in the lower center of the window that says
     Reset Associations
This should do what you want, and allow the proper startup of the addin, etc
6 REPLIES 6
Go to
     Reset Associations
Hanyuri
Yes, it is what I want. Thank you so much~ :D
GoodMan
Now in my Mac, i have JMP 11 and 12. The default launch is set to JMP 12. But i prefer to open a jmp table with JMP 11 when i click a data table. How to handle under Mac JMP preference? Thanks.
Jeff_Perkinson
On the Mac the operating system handles this based on which application was installed last. If you've installed both JMP 11 and JMP 12 you'll need to reinstall JMP 11 in order to make that the default application.
-Jeff
GoodMan
Thanks
aumair
I am using a server at my work, which has both jmp 12 and 11 installed, but default is 11. How may I change the default to 12?
Thanks!
